Text boxes do NOT port between Windows and Android versions
andyhornblower
Post by andyhornblower »
Hi All,
I hope that you can help me!
I have a Workbook with 10 worksheets, each sheet requiring an identical textbox.
This is no problem at all, until I send the file to my Android tablet to work on. - The textbox(es) is completely missing (or has been put somewhere I have so far been unable to find!) I can find no reference anywhere to any need to lock/save/whatever, textboxes into the document.
Can anyone help?
Thanks in advance,
Andy Parker
Re: Text boxes do NOT port between Windows and Android versions
Thanks for reporting this problem. Please share the associated file of PlanMaker 2021 in which you are getting this problem so that we can do further investigation for resolution.
viewtopic.php?f=383&t=20683
