Calculation fields use wrong decimal separator
pavaros
Post by pavaros »
When entering a calculation field, it always uses the English decimal separator (point), not the one that was set in File -> File Management -> Document Properties -> View -> Options -> Decimal separator. Also always the comma is used for the thousands separator. This applies both to the source fields of the calculation (which are incorrectly interpreted with repect to the separators) as to the displayed results.
Re: Calculation fields use wrong decimal separator
Thanks for reporting this problem. I was able to reproduce it and forwarded the details to our development team.
pavaros
Post by pavaros »
Thanks!
Paul
For calculations there is no setting in TextMaker and TextMaker actually use the system settings for this task.
