Old accent issue seems to have been eliminated with 1020 upgrade
kgha
Post by kgha »
It started back in 2018 and persisted in SM2021-1018:
https://forum.softmaker.com/viewtopic.php?f=305&t=17751
I've lived with it and the workaround starting SM with export LANG=sv_SE.UTF-8 (which caused trouble with file/foldernames containing letters å, ä, ö).
Just noticed that the 'export' parameter is no longer needed. Don't know if this is fixed in the 1020 upgrade or if the reason is some upgrade to my system (Slackware -current) during the last weeks. A pleasant surprise, whatever the reason, and thanks to the developers if they're behind it.
Re: Old accent issue seems to have been eliminated with 1020 upgrade
Thanks for the confirmation of the resolution of this problem.
