Footer display not updated after change
Tom123
Post by Tom123 »
Dear SoftMaker Team,
I have created a simple test presentation (attached) using the default presentation template of Presentations Professional 2021 (rev S1016.0624) 64bit. I have
  1. entered some information into the title slide,
  2. added a second slide with some information
  3. and enabled and inserted a footer with the text "This is the footer 2".
  4. Afterwards I have saved the presentation into a pptx file and closed presentations21.
  5. Then I restartet presentations21 and reloaded the test presentation,
  6. I opened the dialog "Insert > Header and Footer" and removed the string " 2" from the end of the footer and clicked "Apply to all".
Very much to my surprise, the footer string on both slides did not change. It still reads "This is the footer 2"! However, when I close Presentations21, a dialog pops up asking me "Do you wish to save your changes to TestPresentation.pptx?".
So it seems, the footer change is recognized but not displayed by presentations21.
Please find the corresponding presentation attached in order to reproduce this issue. I would appreciate, if it would be fixed in the next update of SoftMaker Office 2021.
Regards
Tom
(34.39 KiB) Downloaded 5889 times
Re: Footer display not updated after change
Thanks for reporting this problem. I was able to reproduce it and forwarded the details to our development team.
