open worksheets of unknown count in same workbook
Princy557
Post by Princy557 »
HI,
How would I manage to open a list of x number of worksheets all in the same workbook, access a couple of fields and add them to a summary field on a new workbook.
The worksheets are going to be fixed format titles, such as Invoice 20200811-01, Invoice 20200812-02
How do I work out how many there are, or do I just scan in some way.
IS it possible, is it using Basic?
Any thoughts?
Regards
Regards
Princy557
Re: open worksheets of unknown count in same workbook
Yes, it is possible by using BasicMaker scripts. Please refer to the BasicMaker manual for the development of such a script to achieve this task.
Princy557
Post by Princy557 »
HI Supertech,
Thanks, however I had hoped for a few more hints on the subject.
But never mind, thanks for responding
Regards
Princy557
Check out the "Worksheets" collection in the BasicMaker manual. It lets you enumerate all worksheets of a workbook.
Princy557
Post by Princy557 »
Thanks Martin-k
Will feedback later, sorry but probably with a follow up question.
Regards
Princy557
Princy557
Post by Princy557 »
Well I've pratted about for quite a few hours but up to now have not managed to so what I want.
If someone has the time to spend 10 minutes or what you can spare to tell how to do it please.
I have done nothing more that confuse myself with all this modern referencing and linking to other worksheets.
If you know please let me know.
I also need it to change a cell in the same row to the current date to indicate last time accessed.
Original Post was:
Princy557 wrote: Tue Aug 18, 2020 11:59 am How would I manage to open a list of x number of worksheets all in the same workbook, access a couple of fields and add them to a summary field on a new workbook.
Regards
Princy557
