Purge unpinned file list
canuck
Post by canuck »
The drop down menu on the menu bar shows both pinned and unpinned files that have been recently opened.
The option to clear all unpinned files appears to work, but the unpinned files re-appear when Textmaker is closed and re-opened.
Clearing the unpinned files one at a time does clear them permanently.
Re: Purge unpinned file list
Thanks for reporting this problem. I have tried to recreate this problem with removing unpinned files one by one and remove all also. But whenever I reopened TextMaker it didn't show removed unpinned files. Can you please share screenshots before and after reopening the TextMaker which will show the problem.
