Bug Shell() Object
Mike Sanders
Bug Shell() Object
Post by Mike Sanders »
Code: Select all
Sub Main
    Shell("Calc.exe", 1)
End Sub
Syntax error...
Re: Bug Shell() Object
You are confusing function calls and statements.
Use either:
returnValue = Shell("Calc.exe", 1)
Or:
Shell "Calc.exe", 1
Mike Sanders
Witness:
Shell("Calc.exe")
Yes, that happens to work because it has only one parameter. "Print 1" is the same as "Print (1)".
shell ("calc.exe"), 1 would also work because you are just bracketing one of its arguments.
