User Interface selection
ADZ20
Post by ADZ20 »
Starting TextMaker 2021 brings up the window to select a "User Interface". 6 options appears. If any, but the 1st ribbon option, is selected the same "User Interface" selection window reappears. Selecting the 1st option or Cancel completes the opening of TextMaker. What is the fix? Thanks
Re: User Interface selection
Thanks for reporting this problem. I tried to reproduce this problem but not getting the interface selection screen again, no matter which interface out of 6 I select. Please share a screenshot of the problem so that we can diagnose it.
If you don't have any specific settings or documents saved in SoftMaker Folder, please rename the Documents/SoftMaker folder and check this problem again. Renaming this folder will reset all the settings to fresh which you can recover later.
ADZ20
Post by ADZ20 »
Renaming the folder seems to have resolved the issue. Thanks.
It also resolved my missing printer issue.
It's good to know that both of your problems are resolved.
