SendKeys behavior is erratic...
americanaustralian
Post by americanaustralian »
When I use SendKeys, and I run the script using F8 to step through it, the SendKeys commands don't work. If I run the script using F9, the first instance works, the second doesn't do what's expected, and the third causes a system alert beep, otherwise does nothing at all.
Here's the script:
Sub Main
' ***** Declare Variables In Subroutines *****
' ***** Assign PlanMaker object *****
' ***** Using an existing Workbook *****
pm.Visible = True
pm.Activate
SendKeys "No Action" 'Sent text to cell as expected
MsgBox "Action text sent"
' CTRL-h is to open the Search and Replace Dialog
SendKeys "^h", True 'Appended "h" to the same cell as above
MsgBox "Ctrl-h sent" 'Apparently no CTRL was sent
' ALT-l is to trigger Replace All in the Search and Replace Dialog
SendKeys "%l"
MsgBox "Alt-l sent"
Set pm = Nothing
End Sub
Re: SendKeys behavior is erratic...
I have checked the script and this is not working because of the following problems:
1. Once you execute
It activates the cursor position inside the activate cell which makes the next statement
SendKeys "^h"
Non-executable because this can execute only when cursor is not in the cell. To avoid this please send Enter Key after that so the code will be:
SendKeys "{Enter}"
2. After opening the Search dialog box using
SendKeys "^h"
you opened another message box which disturbed next statement for sending Alt+l
SendKeys "%l"
Please test the following code with F9 after corrections. This will add "No Action" and then replace "No" with blank:
Code: Select all
Sub Main
pm.Visible = True
pm.Activate
SendKeys "{Enter}"
SendKeys "No"
SendKeys "%l"
Set pm = Nothing
End Sub
americanaustralian
Didn't occur to me to exit the cell first. Thank you for the solution...
Return to “BasicMaker 2018 for Windows”
