Getting rid of horizontal lines
wbrells
Post by wbrells »
After opening a file created by an OCR program I'm getting some horizontal lines (some light, some dark) that I just can't delete! The attached sample document shows both types of lines. (This example shows the lines problem in a table cell, but the same problem shows up when no table is involved.) Can someone, hopefully, explain how I can delete these annoying lines?? Thanks, Wayne
Line.docx
(13.03 KiB) Downloaded 2036 times
wbrells
Re: Getting rid of horizontal lines
Post by wbrells »
Solution found! Select the line BELOW the unwanted line and then go the Paragraph > Borders. Select the None option and then click on OK. The line should go away. Wayne
