Dark cells from template aren't copied?
KaijuHK
Post by KaijuHK »
I changed the Normal.pmvx template so all cells were black and text was white.
However, when I copy and paste these cells, they leave white cells again. :(
Is it possible to keep all cells black, like how it is set in the Normal.pmvx template?
Re: Dark cells from template aren't copied?
Unfortunately cutting cells always leaves white cells behind. However, I'm going to make a feature request to the product management. Thanks!
The correct way to dot his is to change the 'Normal' cell style, like in the attached file.
This change was made by:
Home | Cell Styles | Manage Cell Styles | Normal | Cel... | Shading | 38%
dark cells_style.pmdx
(5.45 KiB) Downloaded 2496 times
