Folks,
When exiting from TextMaker I seem to frequently get an error message from Microsoft Word as shown in the attached image. This seems very odd since MS Word isn't running at the time the message appears! The error message (and one following) go away after I click on OK and everything seems to be working correctly. Would anyone have an idea why this annoying message has started to show up and how I can prevent it? Thanks, Wayne
Strange message from MS Word when closing TextMaker
- Word_Error.jpg (11.31 KiB) Viewed 27662 times
Re: Strange message from MS Word when closing TextMaker
Please let us know if you get this message every time when you close TextMaker or sometimes?
Please restart your computer > open the same document(in which you getting this error) in TextMaker > Exit it and let us know if you get this error in this instance also.
Please also share your sminfo file which you can generate by clicking on '?' > About > Write system information.
I was mistaken - the MS Word error messages occurred when I did an Insert > Document where both the original document and the inserted document were produced by TextMaker. There are two error messages generated as shown in the attached image. I've also attached the sminfo.txt file. Hope this helps! Wayne
- sminfo.txt
- (18.79 KiB) Downloaded 4789 times
- Contact:
Please show the full screenshot.
It is possible that the Open file dialog creates a preview of the document using Microsoft Word. Does it make a difference if you turn off the preview in the file dialog?
I've turned off the Live Preview option under File > Options > Appearance to see if that helps. I suspect that may, indeed, be the cause of this problem. Is there any way to specify what program should be used for doing previews? Thanks, Wayne
- Contact:
Live preview is something different. The Windows file dialogs let you show previews of documents, that's what I meant.
Windows decides, based on registry settings, which program provides document previews.
