When using basic bullets Ctrl-M increases the indent. I think the size of the indent is 1.25cm. How can I reduce that size, to perhaps 0.5cm?
Indenting bullets
Re: Indenting bullets
If you have increased the size using Ctrl+M and want to reduce the size, you can simply press Ctrl+Shift+M to do that.
If you want a customized size you can use moue to adjust it on the ruler on the top.
- SoftMaker Office NX
- ↳ TextMaker NX for Windows
- ↳ PlanMaker NX for Windows
- ↳ BasicMaker NX for Windows
- ↳ TextMaker NX for Mac
- ↳ PlanMaker NX for Mac
- ↳ Presentations NX for Mac
- ↳ TextMaker NX for Linux
- ↳ PlanMaker NX for Linux
