Delimited text file - error when embedded tabs are not delimiters
nicholassmall
I'm using "!" as my delimiter in a text file; some of my fields have embedded tab characters. During the import process, when I specify my delimiter the preview is correct but, upon import, the delimiter following a tab is ignored.
- MembersX.TXT
- (892 Bytes) Downloaded 5642 times
Re: Delimited text file - error when embedded tabs are not delimiters
Indeed! I'm going to report the issue to the developers. Thank you!
The issue has been fixed and the fix will be included in the next service pack.
