Paragraph shading - small bug/issue
hla
Post by hla »
Paragraph shading is not applied correctly when you have paragraphs with indent, and the paragraph itself is not long enough to wrap to a new line - long paragraphs "force" correct rendering, while short paragraphs don't fill the left section of the document with the desired background color...
Screenshot of the issue.
small_render_bug.docx
Sample file that showcases the issue.
(79.66 KiB) Downloaded 1801 times
Re: Paragraph shading - small bug/issue
I reported the issue to the developers. Thank you!
