Thicker lines in graphs?
JezShed
Post by JezShed »
Hi all,
Is it possible to increase the maximum line thickness available for graphs (in this case the X/Y Scatter).
I've attached a PM2018 file that shows a graph with 2 curves plotted on it. I'd like one of the curves to be much thicker (the full sine wave one) so that is is not obscured by the one in front.
The maximum available thickness of the curves is not very thick.
Additionally, the "dashed" format of the curve does not work well when there are lots of points in the curve.
Regards,
Jez
RMS output calculation.pmdx
(33.6 KiB) Downloaded 4899 times
Re: Thicker lines in graphs?
Hi, we already have an ongoing feature request for these issues. Unfortunately, you'll have to wait. In the meanwhile, you can add a shadow to the line to make it more visible.
