Can somebody please say why this (from the Help File)...
Sub Main
MsgBox "Today is " & Date & "."
End Sub
...fails with 'Type mismatch.
Thank you
Type mismatch on Date
Valeri Vlassov
Re: Type mismatch on Date
It works well for me:
Sub Main
End Sub
please try simply:
MsgBox Date
does it work?
Sub Main
End Sub
please try simply:
MsgBox Date
does it work?
Thank you Valeri, sorry for the delay due to my being indisposed.
I tried your suggestion
Sub Main
MsgBox Date
End Sub
and oddly still get error on line 2: Type mismatch
Perhaps there is some kind of setting in Basicmaker causing this.
Sub Main
MsgBox Date
End Sub
- Contact:
Works just fine here in 32 and 64 bits. Are you running the current revision 974?
Thank you for your reply. Yes 974.0203 64bit
Really baffled
EDIT
just tried the following from another post and get the same on line 6
Dim pm as Object
pm.Application.Visible = True
pm.Workbooks.Add
pm.ActiveSheet.Range("A1:A1").Item(1, 1).Value = date
dateFromCell = pm.ActiveSheet.Range("A1:A1").Item(1, 1).Value
MsgBox "dateFromCell is " & dateFromCell
Set pm = Nothing
Really baffled
EDIT
Dim pm as Object
pm.Workbooks.Add
Set pm = Nothing
