Bug with ComboBox
enonod
Bug with ComboBox
Post by enonod »
I have made a dialog as per your example using ListBox, ComboBox.
I also tested with ListBox and DropListBox.
They all return the correct selection EXCEPT the ComboBox which ALWAYS returns the first item in the list.
Code for pasting into Editor below. Please select anything but the first item and press OK.
Code: Select all
Option Explicit
Dim pm as Object
	pm.Visible = True
	pm.Activate
Dim AList$(3)
	AList(0) = "Cat"
	AList(1) = "Dog"
	AList(2) = "Elephant"
Dim BList$(3)
	BList(0) = "Sun"
	BList(1) = "Rain"
	BList(2) = "Snow"
Begin Dialog EnterData 1000, 400, 155, 100, "Enter Data"
	CancelButton 5, 85, 40, 10
	OKButton 50, 85, 40, 10
	ListBox 5, 5, 40, 80, AList$(), .ListBox1
	ComboBox 95, 5, 55, 80, BList$(), .CmboBox1
	TextBox 50, 5, 40, 10, .TxtBox1
	Text 57, 17, 40, 10, "£ Amount"
	TextBox 50, 40, 40, 10, .TxtBox2
	Button 55,55, 10, 10, "-"
	Button 75, 55, 10, 10, "+"
End Dialog
Dim dlg As EnterData, btn%
btn = Dialog (dlg)
If btn = -1 Then
	MsgBox "Chosen:  "  & AList(dlg.ListBox1) & " - " & BList(dlg.CmboBox1)
End If
Valeri Vlassov
Re: Bug with ComboBox
Post by Valeri Vlassov »
Please use Function Dialogfn for this (changes are marked as ###) :
Option Explicit
Dim pm as Object
pm.Visible = True
pm.Activate
Dim AList$(3)
AList(0) = "Cat"
AList(1) = "Dog"
Dim BList$(3)
BList(0) = "Sun"
BList(1) = "Rain"
BList(2) = "Snow"
Dim positionInBList '### added
Begin Dialog EnterData 1000, 400, 155, 100, "Enter Data", .Dialogfn
ComboBox 95, 5, 45, 80, BList$(), .CmboBox1
Text 57, 17, 40, 10, "¥s Amount"
End Dialog
btn = Dialog (dlg)
If btn = -1 Then
' MsgBox "Chosen: " & AList(dlg.ListBox1) & " - " & BList(dlg.CmboBox1) '### deleted
MsgBox "Chosen: " & AList(dlg.ListBox1) & " - " & BList(positionInBList) '### changed
End If
'####### added
Function Dialogfn(ControlID$, Action%, SuppValue%)
If ControlID$ = "CmboBox1" Then
positionInBList = SuppValue%
End if
End Function
enonod
Post by enonod »
Thank you Valeri for your assistance. I apologise for the delay but I have been indisposed.
Return to “BasicMaker 2018 for Windows”
