Merge tables
Yash Pal
Merge tables
Post by Yash Pal »
Is there any way to merge 2 or more tables into 1 table. There is 'merge cells', 'split cells' and 'split table', but no 'merge tables'
Re: Merge tables
Place the caret between both tables and use Backspace or Delete to remove all whitespace. Then the tables automatically merge.
Yash Pal
Re: Merge tables
Post by Yash Pal »
Thanks. Will try.
