doc file is not opening
sopsop
Post by sopsop »
Hello and thank you in advance. I can't open first file in textmaker, but can open second one.
Cant' find out what's the difference between them and how to open first file in tetmaker.
( I can only open first file in MS word, resave it into doc naming "second" and then open it in textmaker)
second - declaration.doc
(37 KiB) Downloaded 4271 times
first - declaration.doc
(55.93 KiB) Downloaded 4210 times
Re: doc file is not opening
Your file is not a DOC file. It's an XML file. If you open it in notepad you'll see it starts with:
<?xml version="1.0" encoding="utf-8"?>
TextMaker doesn't support XML files.
