DBF dates for mail merge
taccy
Post by taccy »
I wish to create some labels from a data file. When I save the file (in Planmaker) as DBF the date format changes to a number formatted as yyyymmdd,
which is not recognisable to the (elderly) users of the labels- but Planmaker does not seem to let me reformat the cells to the correct date format.
Is ther any way to do this. I have tried using CSV files -but the labels do not work well with that fomat -just showing mutliple instances of the last field.
Is there an easy way to reformat the DBF date fields? for us in making lables.
Re: DBF dates for mail merge
Hi, I created a PlanMaker file with regular dd/mm/yyyy dates (see attached).
I then I saved the file as dbf and opened it in notepad and noticed that in fact they are stored as yyyymmdd there.
However when I assign the DBF in to a TextMaker document, the dates are displayed as dd/mm/yyyy.
file.tmdx
(12.86 KiB) Downloaded 1984 times
database.pmdx
(5.9 KiB) Downloaded 1927 times
database.dbf
(128 Bytes) Downloaded 2182 times
taccy
Post by taccy »
Thanks Miguel, your file showed me that it could be done and meant that I should explore further.
I have got it working, still not sure of the exact process, but it seems to be dependent on opening the initial file in the 'Normal.tdmx' format. On my list the top 'default' option results inusing the dbf nuerical date.
I'm not sure whether the default is something that I have produced or not. Its working and thats what matters.
Thanks again
I'm glad it worked! It may be related to your Windows regional settings when you created the original file.
Return to “SoftMaker Office 2018 for Mac (General)”
