I've noticed when you put an image as background of the page, it is arranged as mosaic. Is it possible to change this arrangement to adjust to the page size or mantain centered?
Thanks!
Image background
- Contact:
Re: Image background
This function does not offer this, as it needs to be compatible with Microsoft Word. What you are looking for, can be achieved by going to master-page view and placing a picture frame on the master page.
elmonopascual
Hi Martin. Thanks for the workaround. It works!
Additionally, is helpful if you lock the image and place it behind the text to achieve the effect of a background.
The only thing is a bit annoying (not a big thing) when you click on the document where there is no text, the image is selected. Is there a way to make it unselectable?
