I have softmaker in linux mint. Calibri fonts look bad compared to others. I solved that in libreoffice for example. When I start softmaker office I get the following message: "The initialization of the OpenGl library failed. The Xrender library will be used". This problem only occurs with softmaker. So far I must expand the text to 125% so that it looks correctly.
Is there any solution?
PD: I have the updated drivers of my nvidia card
Greetings and thanks.
problem with OpenGl and Calibri Font
Re: problem with OpenGl and Calibri Font
When SoftMaker Office disables OpenGL, the software still works, and it has no effect on the text quality.
You can change the type of anti-aliasing in File | Options.
- SoftMaker Office 2021
