I have a number of documents which use tables extending over several pages, and frequently want to insert a page break so as to keep groups of table rows together on a page. The menu item "Table"/"Row properties" has two options which should enable this - "Keep together with next row" and "Break page at row", and most of the time this works; however, sometimes when I have formatted a document and saved it, the next time it is opened it has "forgotten" the instruction, and the page break occurs in the middle of the group of rows.
Secondly, if I open a table which was originally formatted in MSWord and insert rows, although the page looks fine on the screen the printed page shows a significant difference in weight between the borders to rows formatted in MSWord and the borders to rows formatted in TextMaker. I have to select the whole table and reset the cell borders, so that they then print correctly.
JLDP
Table formatting issues
Re: Table formatting issues
Could you please attach a sample file?
- SoftMaker Office NX
- ↳ TextMaker NX for Windows
- ↳ PlanMaker NX for Windows
- ↳ BasicMaker NX for Windows
- ↳ TextMaker NX for Mac
- ↳ PlanMaker NX for Mac
- ↳ Presentations NX for Mac
- ↳ TextMaker NX for Linux
- ↳ PlanMaker NX for Linux
