How to find graphics in TextMaker?
anand
Post by anand »
I want to use ^g or equivalent to find (and replace) graphics, which I often use in MS Word. What is the equivalent code for that. I tried ^g and ^o but these codes do not find anything.
Any help would be appreciated.
Re: How to find graphics in TextMaker?
Post by sven-l »
You can search for graphics by using the red button in the bottom right corner of the program window. Just make sure to select "Picture" from the drop down menu and use the Up and Down icons to find the next/previous occurrence.
