Date entry using keyboard shortcut
Jon Polish
Post by Jon Polish »
I am running the latest update of Softmaker 64 bit under Windows 7 Professional 64 bit. The system date is set to display yyyy-mm-dd or 2018-10-19. However, when I use the keyboard shortcut (CTRL + .), the date appears 10-19-2018. Thinking that PlanMaker might be using the long date system format, I modified that but got the same results.
How can I use the keyboard shortcut to enter the current date in the format I specify?
Thank you.
Jon
Re: Date entry using keyboard shortcut
Post by sven-l »
PlanMaker always uses the system date/time settings. For me it's dd.mm.yyyy (with German regional settings). Please check your system settings again.
Jon Polish
Thank you Sven. The system is set for the short date to read yyyy-mm-dd (or 2018-10-23). The long date is set for October 23, 2018. PlanMaker inserts 23-10-2018 when I use the keyboard shortcut. I have tried changing the system long date, but this has no effect. Please see the attached screenshots.
Graphic_2018-10-23 9_18_18 AM.jpg (20.48 KiB) Viewed 24608 times
Post by sven-l »
I can now reproduce that issue and will report it to the developers.
Jon Polish
Thank you Sven.
Jon
