Presentations Won't Start
JamesL
Post by JamesL »
Hi, I've just installed SOF 2018 on two W7 PCs, both SP1 and fully up to date. Installation went fine, Textmaker and Planmaker work fine, but Presentations won't launch on either machine. Review of Task manager indicates that there's not even a process running. Please can someone assist? Many thanks, James
Re: Presentations Won't Start
Post by sven-l »
Please try to start Presentations with the Parameter -disableopengl. Does it work?
Additionally, please start it with parameter -debug and send us the log file (prlog.txt). This will let us check the OpenGL capabilities of your graphics card.
ezodoc
Post by ezodoc »
same problem
OS - Win Server 2012
link - "C:\Program Files (x86)\SoftMaker FreeOffice 2018\Presentations.exe" -disableopengl -debug
no debug info :(
-debug creates the file prlog.txt in My Documents. You need to search for the file there and send it to us.
JamesL
Post by JamesL »
Hi Sven, just got around to this again. Running with -disableopengl works and seems to read files OK. 2x rlog.txt attached, opengl disabled (runs OK) and enabled (hangs).
Thoughts? Many thanks,
James
prlog2.txt
(6.99 KiB) Downloaded 2659 times
prlog.txt
(28.19 KiB) Downloaded 2478 times
Post by sven-l »
JamesL wrote: Fri Oct 19, 2018 6:27 pm Hi Sven, just got around to this again. Running with -disableopengl works and seems to read files OK. 2x rlog.txt attached, opengl disabled (runs OK) and enabled (hangs).
James
Thank you! I will report this to the developers.
Post by sven-l »
The issue has been solved and won't occur anymore with the next service pack.
Return to “Presentations 2018 for Windows”
