Hello
I have a document. It's basically a form made up entirely from tables.
What I'd like to do is take the contents of one or more cells in a table and pass them to a new document so I could have an entry on my form in a new document.
I can do this to different sections in a document in plain Textmaker, but it would be more elegant if I could do it with a script and create a new document rather than a plain one.
Thanks for looking! I'd appreciate any insights.
Can I create a new Textmaker document containing the fields from a table?
Re: Can I create a new Textmaker document containing the fields from a table?
Could you please attach a sample file or send one to forum (at)softmaker.com?
Thanks for your quick reply Sven-l.
What I'd like to do is take have a form like the attached example "The new form.tmdx" with four textboxes, and have people fill it out in form mode.
I'd then like to write a script which generates a file based on the attached template "Data to here please.tmvx" with the data from the filled out form in the four textboxes.
Ideally, I would like the document generated from the template to be named after two textboxes.
Is it possible?
Is it possible?
- The new form.tmdx
- (8.06 KiB) Downloaded 2161 times
- Data to here please.tmvx
- (8.01 KiB) Downloaded 2290 times
No, I don't think it would work with a script. What you could do in TextMaker is to attach a database (e.g. an dbf file) with your database in it. Then insert the database fields into the table (mail merge).
It's quite a complicated form. I think it might be a bit clunky to just enter the fields into a database.
I can see myself having to write something in Python to do this job. Thanks anyway.
