Tables cells shows grey text instead of black
vash83
Post by vash83 »
Hi,
I bought SoftMaker Office for Linux.
This is my problem. Text colour is set up to default value (black), but it appears light grey.
It happens only into table cells.
What should I do to fix this issue?
I've been working around this issue setting the dark grey as text colour.
Thank you.
Re: Tables cells shows grey text instead of black
Post by sven-l »
Please attach a sample file or send it to forum(at)softmaker.com.
vash83
Post by vash83 »
Here I am!
I've attached it.
Sample_for_support.pmdx
(6.61 KiB) Downloaded 6245 times
Post by sven-l »
The grey font color is part of the table style you have chosen for your table. You can change the table style if you want another font color.
vash83
Post by vash83 »
Hello,
thank you for your answer. I'm sorry but I don't agree so much. If I chose black font colour, it should be black. It's not set up as "Automatic" like MS Excel. I updated the sample file with further two tables and all of them have light grey with more o less intensity but not black anyway.
Is there any chance to edit the table style parameters?
I attach you the updated sample file.
Thank you.
(7.82 KiB) Downloaded 6147 times
Post by sven-l »
Ok, this is only reproducible in Linux but not in Windows. I will inform the developers.
Return to “PlanMaker 2018 for Linux”
