I'm going to become a subscriber. You have a great product, and I have to work on Windows machines as well as Linux ones.
I need to ask a question though. If I've installed Softmaker on five computers but then have to replace one, can I remove the product from the dead computer and install it on a fresh one? How do I do this?
Deregistering old computer
colonel_panic
Re: Deregistering old computer
There should be no problem when you replace a single machine. Just use the same product key again. If you receive an error message, contact the support team via support(at)softmaker.com.
- SoftMaker Office 2021
