Lines at bottom ofpage
maryanner2017
I printed my document which was 7 pages. At the bottom of every page is a line. How do I eliminate this? Thank you
Re: Lines at bottom ofpage
Could you please provide a sample document? Otherwise it's difficult to find the cause of the issue.
maryanner2017
EXECUTORY AGREEMENT FOR SALE OF REAL PROPERTY
THIS AGREEMENT made the ______day of _______________, 20_______ between
, hereinafter referred to as the “Seller”, and
hereinafter referred to as the “Buyer”.
1. REAL PROPERTY: The Seller, in consideration of the covenants and agreements
on the part of the Buyer herein contained, agree to sell and convey to the Buyer, and the Buyer
agrees to purchase from the Seller pursuant to the terms of this Agreement, a one-family
dwelling located at , as described on Schedule
“A” annexed hereto.
2. PURCHASE PRICE: The Buyer agrees to pay for said premises and the Seller
agrees to accept as the purchase price therefor, ONE HUNDRED SIXTY THOUSAND &
00/100 ($160,000.00) Dollars.
3. METHOD OF PAYMENT: The Buyer shall pay the purchase price as follows:
(a) The sum of $_______________ upon execution of this agreement.
(b) Acceptance by the buyer of the existing mortgage with a current balance in the
amount of $_______________.
(c) By paying to the seller the balance due of FIFTY THOUSAND & 00/000
($50,000.00) Dollars as follows: The sum of THREE HUNDRED SIXTY-NINE & 84/100
($369.84) Dollars per month beginning on the 1st day of _____________, 20_____ and a
similar payment each month thereafter until the 1st day of _____________, 20_____ when
the entire balance shall be due and payable.
4. EXISTING MORTGAGE: It is understood that there are presently no liens
encumbering the premise, with the exception of an existing mortgage with a current balance in
_______________________________________________________________________________________________________________________________
“A” annexed hereto.
Thank you, but we need the original TextMaker document. In your reply, please use the tab "Attachments" visible under the text entry field to upload the file.
maryanner2017
Thank you! For some reason the last paragraph on each page had a paragraph border below. (I have no idea how this was produced, and frankly, I have never seen something like this before.)
Moreover, the whole document was rather badly formatted. It looked as if it had been set up by a person who used to write on a typewriter, not on a computer. For example, there was a paragraph break at the end of each line (and an additional empty paragraph to produce bigger spacing between lines). When working with a word processor, this is not only unnecessary (the program sets the line breaks by itself and line spacing can be adjusted at will using Format > Paragraph...), it is also detrimental for a clean result. Likewise, indents and centering of lines was made by inserting blanks, not using the functions provided by the program.
Attached you will find a new version of your document where these faults have been corrected (and of course without lines at the bottom of the pages).
- jim 1 corr.docx
- (13.39 KiB) Downloaded 3061 times
