Release version continues to crash
Dicky
Post by Dicky »
Whatever the problem, it has not been fixed, and happens (un)reasonably often.
See attached for top of error information.
Whenever TextMaker does crash and I select "Reopen" the last saved version is never restored. Why is that?
Something is not right - please explain how the Reopen process works.
Dicky
Re: Release version continues to crash
Post by Dicky »
Another crash, this time know exactly what occurred:
TextMaker (Mac release version) with 2 documents open. Selected text from one document to paste into the other, used Cmd-C to copy then crashed before able to switch to the other.
If the entire "crash report" would be useful please indicate by reply.
TextMaker crash - copying text.pdf
(254.46 KiB) Downloaded 2285 times
Post by Jossi »
Dicky wrote: Wed Mar 21, 2018 1:10 am Whenever TextMaker does crash and I select "Reopen" the last saved version is never restored. Why is that?
In any case you should go to Tools > Options, tab "Files", and make sure that "Auto recovery" is checked and a short time interval of a few minutes is set, to make sure that in case of a crash you will only lose the last few minutes' work.
Dicky
Post by Dicky »
Another crash in TextMaker, this time after selecting text and then going to "Convert text to Table" from the Table menu. Crashed when clicked on "Convert...".
TextMaker Crash - convert to table.pdf
(245.03 KiB) Downloaded 2436 times
Post by sven-l »
Please provide one or more sample files that let us reproduce the crash (send them to forum(at)softmaker.com).
Return to “TextMaker 2018 for Mac”
