Some issues with numbering and empty background
ArnaudK
Post by ArnaudK »
Hi !
Compared to MS Powerpoint, the attached presentation has some issues :
- Slide 8 : numbering mismatch
- Slide 45 : empty background
Do you replicate the issue ?
Regards,
Note : I used 7zip and multivolumes as we cannot attach large files
tests_003.7z
(1 MiB) Downloaded 2447 times
tests_002.7z
(1 MiB) Downloaded 2418 times
tests_001.7z
(1 MiB) Downloaded 2584 times
ArnaudK
Re: Some issues with numbering and empty background
Post by ArnaudK »
Last volume here
tests_004.7z
(13.51 KiB) Downloaded 2279 times
Post by sven-l »
Unfortunately I cannot unzip your attached archives. It seems they are either somehow damaged or incomplete. Could you please upload the file to a filehoster like Dropbox or Google Drive? Thank you!
Return to “Presentations 2018 for Linux”
