Minor issues on a PPT file
ArnaudK
Post by ArnaudK »
Hi !
Starting from slide 4, we see that text position differs from Powerpoint. The paragraph seems indented instead of hanged. That appears also on slide 5 and many other slides. Why does it differ from PowerPoint ?
Hépatites B et C tests biologiques 2005.ppt
(96 KiB) Downloaded 6157 times
Re: Minor issues on a PPT file
Post by sven-l »
I can see the issue and will report this to the developers. Thank you!
Post by sven-l »
The issue ha been solved and should no longer occur with the next service pack.
ArnaudK
Post by ArnaudK »
sven-l wrote: Wed Mar 07, 2018 10:03 am The issue ha been solved and should no longer occur with the next service pack.
Great, thank you
Return to “Presentations 2018 for Linux”
