I am using Softmaker Office 2018 on Windows 10
I have used Softmaker Office for many years and not seen any issues.
But, with the new version of PlanMaker I find cells being shaded without me asking for it.
Also, the shading appears almost at random, but so far does not appear in cells I have made entries into.
The files I use are in the XLSX format, and I have the issue in several files, all of which I've used for several years.
I have emailed the support team for assistance, but so far have not had a response ( Ticket#2017122408000486 )
I have attached an example of my issue.
unwanted shading appearing in spreadsheets
- Lottery - Shading Error.xlsx
- (31.06 KiB) Downloaded 2589 times
Re: unwanted shading appearing in spreadsheets
Sounds similar to viewtopic.php?f=300&t=17413 and that's now fixed!
I will send you a hotfix, it should solve that issue.
I am also having this problem with a couple of spreadsheets that I have been using with PlanMaker for some time - and without issues prior to the 2018 version. They were previously in xls format but recently I have been saving tham as xlsx. I have only noticed the issue since I started using xlsx. Again the shading is random and seems to be only in empty cells. I have tried creating new xlsx spreadsheets to reproduce the problem but so far it hasn't occurred in them.
The fix for this problem will be included in the next service pack.
I too experienced this in one of my spreadsheet.
The shading was all over the place and it was a mess.
Hi Sven,
I have been experiencing this unwanted shading twice in the last two days, can you please send me the hotfix too?
Looks like the issue happens when you "Select All" on a worksheet and change the font type or font size.
Regards,
Sure. I will send you a PM.
