Open attached DOCX into TextMaker with window normal default size (not maximized) make sure Document Map pane is visible. Now drag the bottom scroll bar left or right, the first and last characters of the line drag or appear multiple times briefly!
This did not occur with TextMaker 2016!
SoftMaker Office 2018 Std x64 rev 918.1128
Windows 10 Pro x64 RS3
nVidia Graphics Driver 388.31 x64
Fonts Drag with Document Map
- Windows 7 Product Keys.docx
- (7.79 KiB) Downloaded 2185 times
Re: Fonts Drag with Document Map
Still present in SoftMaker Office 2018 Std x64 rev 920.1214
- sminfo.txt
- (45.77 KiB) Downloaded 2077 times
I could not reproduct this issue here with the latest service pack (Rev.920) in Windows 10 64bit. Which Windows and graphics card are you using? Please attach the log file you can create via the ? icon in the upper right corner (under "About").
Windows 10 Pro x64 RS3 or Fall Creators Update
Asus Strix Geforce GTX960 4Gb
sminfo.txt attached to previous post
Thank you! I will report this to the developers. Do the characters on the screen stay this way or does the correct font display re-appear after some time?
Only while scrolling horizontally, once you stop it's fine!
Sorry for taking a while to respond.
Malwarebytes decided it would be fun to mess me around with one of their betas, wonderful xmas present...
According to our developers this is definitely a driver issue. We cannot control how the screen is painted. Maybe it works with default scaling set to 100%.
