spreadsheets in window
knijn001
Post by knijn001 »
With Planmaker16 I'm used to work on several spreadsheets in one window.
See attachment.
That option is not possible in Planmaker18?
Re: spreadsheets in window
No, because we have changed from the old and outdated MDI interface to a modern style that lets you open documents in different tabs AND in separate windows. The advantage is that you can move windows to multiple monitors.
knijn001
Post by knijn001 »
aha, now I see, problem solved
thanks for answer
SS338
Post by SS338 »
Hi, as a follow-up to this question, how do you open multiple documents in the same window but separated via tabs?
Post by sven-l »
SS338 wrote: Fri Jul 27, 2018 10:42 pm Hi, as a follow-up to this question, how do you open multiple documents in the same window but separated via tabs?
Either open multiple existing documents one by one via File=>Open or use CTRL+N to create new files.
However, this feature is not available with FreeOffice. In FreeOffice, documents always open in separate windows.
