Characters are not displaying correctly
Hi, I just installed freeoffice 2018 to give it a go. I tried some of my xlsx files but certain numbers do not display properly. Instead there is a line of ########. I noticed that this usually is with numbers with a lot of decimals, but not with all numbers with many decimals. I tried to copy the whole file into a new one and then it does it to other numbers with many decimals, but not the same ones, and the others that before didn't display properly, now they do. However, and this is a strange thing, when I change the font of the cells with the ####### symbols to Scheherazade, it shows an actual number. Any way to fix that?
Re: Characters are not displaying correctly
######## means that the column with is too small to show the complete numbers. Please enlarge the column with until you see the numbers.
It worked. Thanks a lot.sven-l wrote: Wed Nov 14, 2018 10:12 am ######## means that the column with is too small to show the complete numbers. Please enlarge the column with until you see the numbers.
