Cell Comment shadows not saving
StevieW
Post by StevieW »
Hi, I reported issues with PlanMaker not saving cell Comment shadows back in November 2023 and again in April 2026 and the bug is still not fixed so I thought I would report it again. I use Comments a lot and for the last three years I have not been able to use them as I would wish as PlanMaker does not save them correctly.
I even tried your 2026 and the bug is still there.
However, I have tried a few experiments myself to get around the problem. This is what I have found which might help you resolve the issue.
1. Open a new document in PlanMaker, select any cell and add a Comment.
2. Edit the Comment by opening the Object Properties window
3. Go to the Shadows tab and select the top right box under Simple Shadows
4. Set the Options to 40% grey, Blur 10pt and Transparency to 50%
5. Now save the document in three different formats, Excel 97-2003 .xls, Excel .xlsx and your own format .pmdx
6. Close the document and PlanMaker
7. Open PlanMaker again and then load each of the three documents you just saved
8. The only document which saves the shadow format correctly is Excel 97-2003 .xls the other two formats save the cell with an ugly shadow with no Blur or Transparency.
As mentioned this issue applies to PlanMaker 2024 and 2026 versions. I use the paid version of 2024 running on a MacBook Pro MacOS v27.2.1
Return to “PlanMaker 2024 for Mac”
