Form
Jon Polish
Form
Post by Jon Polish »
In Excel and LibreOffice Calc, there is a function that allows the user to select a contiguous range and enter data using the form created in the window. Kind of like a database. You can fill the cells and go to the next record. All of this populates the defined spreadsheet range.
I cannot find this in PlanMaker. Does such a feature exist and if not, could it be added? I find it very useful.
Thank you.
Jon
Return to “PlanMaker for Windows”
