[Question]: Are ‘Delete’ and ‘Reset’ different?
Văn Quang Nguyễn VN
Post by Văn Quang Nguyễn VN »
Currently, the user guide pages for Textmaker NX 2024 and NX 2026 both feature screenshots of the ‘Paragraph style’ dialogue box. These show a ‘Delete’ button. However, in the mobile version of Textmaker NX 2024, it is labelled ‘Reset’.
What’s going on?
I didn't know much about the English language, so I had to use a translation tool. I love Vietnam. My hometown 🇻🇳 🇻🇳 🇻🇳 🇻🇳
Maths
Re: [Question]: Are ‘Delete’ and ‘Reset’ different?
Post by Maths »
I’m really confused and at a loss. Is the manual wrong, or has the mobile version of Textmaker mislabeled the command buttons?
The fact that the manual says one thing and the software does another has left me unsure of what to do next. Now I’m not even sure if the “Reset” button in the Character Style and Paragraph Style dialog boxes is actually the “Delete” button, as described in the manual.
I think that’s highly likely. The Reset button should actually be the Delete button. I think: If you use the Reset button to delete the “Styles” in the Character Style and Paragraph Style dialog boxes, it doesn’t seem to work at all. It doesn’t delete anything.
What should I do next? I’m really confused.
I love Softmaker and won’t use any other software
I love the Softmaker file format. I I really like Softmaker software because the software updates always include new features
stascheit
Post by stascheit »
The button label changes depending on whether you have created a new character style or are using a predefined character style. The latter can only be reset (when you have edited them, and want to have back the original settings) - and they can never be deleted.
Creating a new character style, however, you will see that the button changes to "Delete".
See the descriptions in this section of the manual, at the end of the page.
https://help.softmaker.com/textmaker202 ... tyles.html
Return to “TextMaker NX for Android”
