I downloaded the latest free font from Softmaker’s ‘free font. De’ website. I typed a few characters, but they weren’t uniform.
I previously downloaded the Micro font from Softmaker’s freefont.de, but I can type normally
Galaxy A04S mobile phone
Android 13
I’ve downloaded the font, but I’m getting an error when typing certain Vietnamese characters
Văn Quang Nguyễn VN
Văn Quang Nguyễn VN
Re: I’ve downloaded the font, but I’m getting an error when typing certain Vietnamese characters
I have dowload Cathedral open font
The reason why you are seeing that is because the font does not support Vietnamese characters so Android uses a fallback. This means: another font is use for those characters that are not present in your chosen font. This is not an error, this is intended. This is how the system tells you: Your font does not support this characters, but I'll display them for you anyway so you can see what the text says.
The solution is simple: change the font to one that supports Vietnamese characters.
