[Error] The "Delete" command button is not working at all
Văn Phước Nguyễn
Post by Văn Phước Nguyễn »
I have discovered a serious bug in Textmaker NX 2024 for Android. I am using a Realme RMX 1941 phone running Android 9. Specifically, when I right-click and select ‘Delete’, the table is not deleted. See the video below.
The ‘Delete Cells’ button on the Table tab works, however. Meanwhile, right-clicking and selecting ‘Delete’ does not work.
Record_2026-08-17-09-15-34.mp4
(7.54 MiB) Downloaded 206 times
Re: [Error] The "Delete" command button is not working at all
Thanks for posting.
The steps you are following will only delete the contents of the table. To delete the entire table, please follow one of the methods below:
1. Press and hold the table to open the context menu, then select Delete Cells → Delete Table.
2. Alternatively, you can delete the table using the corresponding command from the Ribbon.
