Generating a data table of values
vic
Post by vic »
The task I have is: given a input cell, and an output cell (depending on the input cell via biiig block of data and intermediate computations) , create a data table of the output vs input.
So, I can create a long list of input values.
Then what is the easiest way to make planmaker use each input value into the input cell, and compute a corresponding list of ouput values from the Output cell?
So that I can then plot them, for example.
Thank you
p.s. I found that Excel has a special tool for this: "data table", located in: Data//What-if Analysis//Data Table.
The nice thing about it is that you can then color code the table cells and thus you may not even need to plot them!
Re: Generating a data table of values
Thank you for your request. There is currently no equivalent feature available in PlanMaker. I have forwarded your improvement suggestion.
Return to “FreeOffice PlanMaker 2024 for Windows”
