Paragraph styles
Harmo26
Paragraph styles
Post by Harmo26 »
Paragraph styles and Format painter no longer function. I've tried in several .tmdx files.
Thanks,
Johanna
Re: Paragraph styles
Thank you for the report. Both paragraph styles and the format painter work correctly on our test systems, so the cause is likely specific to your installation or to the documents themselves. To reproduce it here, I need a more detailed picture of what happens: a sample .tmdx file and screenshots would help, and a short screen recording would be the most useful of all.
It would also help if you could describe the behaviour precisely. For paragraph styles: does the style list stay empty, does applying a style leave the text unchanged, or does the formatting revert immediately? For the format painter: does the mouse pointer change when you activate it, and does the second click have no effect? Please also let me know the exact version and revision shown under Help | About TextMaker.
Harmo26
Post by Harmo26 »
Thanks for detailed reply. I'll get to work on your 2nd paragraph.
Harmonia
