I format books for both print and for e-book (both Kindle and EPUB) using a word processor. Being able to export from TextMaker directly to EPUB is a blessing, but there's room for improvement.
I prefer to create my tables of contents for e-books manually. When using Microsoft Word, there were two ways to insert a table of contents link to a place in the book. One method is to manually insert a bookmark at the destination point, then to configure a link to that place in the table of contents. This method also works in TextMaker -- but it's cumbersome.
In Microsoft Word, since I used the default Heading1, Heading2, Heading3 ... styles for chapter heads and subheads, it was possible to go to "Insert link" and that would pop up a document map showing all the headings in the document, and I could just pick the one I wanted from the list, customize the text to appear on the table of contents, and that was done. With this method, there's no need to scroll through the document to insert a bunch of cryptic bookmarks. Do it this way is orders of magnitude faster than the first method.
This second method isn't available in TextMaker. Can it be added? Please, please, please?
Feature request
Re: Feature request
Thank you for your post. I have forwarded this improvement suggestion.
In TextMaker as well, once you finalize your book and create the TOC, you can edit the text afterward, and the links will still work fine.
In addition, TextMaker has the advantage that you can create a bookmark for the TOC heading and insert a hyperlink to it in the header or footer, so you can jump back to the TOC from any page.
- SoftMaker Office NX
- ↳ TextMaker NX for Windows
- ↳ PlanMaker NX for Windows
- ↳ BasicMaker NX for Windows
- ↳ TextMaker NX for Mac
- ↳ PlanMaker NX for Mac
- ↳ Presentations NX for Mac
- ↳ TextMaker NX for Linux
- ↳ PlanMaker NX for Linux
