[woff2/ttf] Round trip brotli compress & uncompress
Post your questions, bug reports and suggestions here for SoftMaker fonts.
Michael Uplawski
Post by Michael Uplawski »
What are the implications and considerations if I use a brotli tool to compress, then decompress a font file, first to WOFF2, then back to ttf?
My gained advantage is obvious. You just look at the files.
Licenses are unharmed by the proces AFAIS. Is there anything else that could prevent me from taking this approach? I have not understood if and how glyphs are changed in the process. So my idea does not seem to have any bad sides (that's odd).
However, let me state (again) that the sizes of font-files are of not much influence on the loading speed, when the right techniques are used. For the time being, I am merely “challenged” by the concepts.
TIA.
Edits: false directions.
Edit: Say the German „Elektrische Astschere” a few times aloud, hear the aliteration, to know, what electric loppers do to your 'n' finger.
Edit: « Sécateur Électrique » is also nice.
Last edited by Michael Uplawski on Wed Mar 18, 2026 7:47 am, edited 2 times in total.
There are flatworlders all around the globe. (unknown author)
If we go now, nature may stand a chance. (known author)
lgsl
Re: [woff2/ttf] Round trip brotli compress & uncompress
Post by lgsl »
A tool like FontForge would be able to tell you that since it logs all issues and errors contained on the font file and it provides the required tools to fix most, if not all issues. I could also be used to do the conversion. Just keep in mind that the font licencie must allow you to manipulate the file in such a way
Michael Uplawski
lgsl wrote: Thu Mar 05, 2026 3:34 pm A tool like FontForge would be able to tell you that since it logs all issues and errors contained on the font file and it provides the required tools to fix most, if not all issues. I could also be used to do the conversion. Just keep in mind that the font licencie must allow you to manipulate the file in such a way
Thank you.
I have forgotten FontForge... Although I consider it a powerful tool and have not yet tried your suggestion, I am a little afraid of FontForge. I mean: understanding the WOFF format(s), their structure, and using brotli might spare me the confrontation with that monster... however. I will try FontForge.
For the time being, online converters and the woff-tools available for Debian make me gain 100K on a TrueType font. There are two things to retain here:
1.) 100K is not much on the Web. Almost nothing compared to the other resources that people are used to share, nowadays.
2.) There “appears to be” some disposable stuff transferred with the font-files, irrespective of their file extension.
As regards your concerns for the license.., I left your post intact in the quote above, because this is part of the topic. But I use a lot of OFL Fonts, otherwise fonts that are explicitly allowed for embedding. For FertigoPro I have the authorization by the font author himself, although I found later that the Exljbris EULA already allows embedding of the one font style I use.
When you look at fonts like Lato or the Libertine family.., I wonder what people do, nowadays and why?
Michael Uplawski
Michael Uplawski wrote: Sun Mar 08, 2026 9:58 am For the time being, online converters and the woff-tools available for Debian make me gain 100K on a TrueType font. There are two things to retain here:
Using only fontforge for the compression (aka: Create Font) then woff2_decompress, nothing changes. At least the file-size of the original ttf file and the decompressed woff2 file are identical.
Meaning: The online-converter does more things than it sais and I do not know what I am talking about.
I need more instruction.
For the time being, there is no proposition of a generally applicable procedure and maybe not even any use for it. ](*,)
Edit: And maybe FontForge is really cool.
lgsl
Post by lgsl »
Check the metadata of the packages (Ctrl+Shift+F), that's where things may change. When you do the woff2 => ttf or the other way around with fontforge it won't add anything to the metadata and font tables, other tools may do so.
There are also other things that may explain as to why with one tool the size is the same, with the other, bigger. Validate the file, if you get a bunch of errors, fixing those can reduce the file size, and can help you to find out if the tool you are using is doing something to the glyphs or not.
Return to “SoftMaker Fonts”
