Add StartupWMClass to .desktop files
General questions and answers about FreeOffice 2018 for Linux. Don't post application-specific questions here, but in the appropriate subforum.
jaygambrel
Post by jaygambrel »
I'm not sure if this is the correct place to make this request. When I start TextMaker xprop lists WM_CLASS(STRING) = "tm", "tm" and so the icon for TextMaker doesn't display properly in my dock in Gnome. I added StartupWMClass = tm in the freeoffice-textmaker.desktop file in /usr/share/applications.
This fixed the problem, but I'm guessing that it will break on updates if the .desktop files are overwritten. Any chance you could add StartupWMClass entries to the .desktop files so they will display properly in Gnome?
Re: Add StartupWMClass to .desktop files
You can make a copy of this file and then make the desired changes. On update, your this copy of the file will retain changes.
Return to “FreeOffice 2018 for Linux (General)”
