Some issues encountered after first install
lama
Post by lama »
Hi,..
01. I had to manually Set "Options > Appearance > UI Size" to "Very Small" to properly see app UI
(navigating between tabs was difficult as tabs kept moving 😅 its cool to change tab pages with finger swipe instead)
default screen resolution on tablet is 1752 × 2800 @ 120hz 266dpi
02. I could open file from remote server but couldn't edit/modify/save on remote server
03. Samba and WebDAV Mounting protocols are very much needed for me to access/preview/edit/modify files on my NAS remotely
04. If a spreadsheet is shared and used by more people, once loaded remotely, there requires an option to Sync file to latest changes according to timestamp and give user option to "save new changes only" rather then saving in an overwriting manner that deletes other users changes :|
Re: Some issues encountered after first install
Thanks for your suggestions. I have forwarded this request to our product management...
lama
Post by lama »
I see new beta updates but :roll: still no WebDAV option in File browser.
If Dropbox and Google Drive is there, how hard can it be to implement WebDAV?
(i saw one Dev quoting "Apache Tomcat" for reference towards WebDAV implementation)
:? if you guys cannot implement, do you guys have suggestion of an App that can mount/map Networked path as local folder?
Ultimately, helping users to use Softmaker apps easily should be developer's priority :roll:
Return to “BETA: PlanMaker for Android”
