Unusable with Bluetooth keyboard on Boox Note Air
vtpoet
Post by vtpoet »
FYI: While the app works fine on my Samsung Tablet, Textmaker loses keystrokes when using the Boox E-Ink Tablet. This seems to be a problem with Textmaker. Using Googledocs or other writing apps doesn't present this issue. While there's a delay between what I type and what appears on the E-Ink Tablet (while using Google Docs or other Writing apps) everything I've typed is eventually captured and appears.
With Textmaker, sentences turn into gobbledygook as half of the keystrokes are lost, rendering the application unusable on Boox with a bluetooth keyboard.
vtpoet
Re: Unusable with Bluetooth keyboard on Boox Note Air
Post by vtpoet »
Testing with Virtual Keyboard. Keystrokes are also lost, mainly the space bar. Textmaker doesn't seem to capture keystrokes that don't immediately appear on the display.
vtpoet
Post by vtpoet »
Update: Tested the older version of Textmaker HD on the Boox Note Air and there were no issues . Based on comments on the other thread, this seems to be a bug unrelated to the E-Ink display or tablet...
Thanks for reporting this problem. I have forwarded the details to our development team.
vtpoet
Post by vtpoet »
F̶o̶r̶ ̶t̶h̶e̶ ̶s̶a̶k̶e̶ ̶o̶f̶ ̶t̶h̶o̶r̶o̶u̶g̶h̶n̶e̶s̶s̶,̶ ̶c̶o̶m̶m̶e̶n̶t̶i̶n̶g̶ ̶h̶e̶r̶e̶ ̶t̶o̶o̶:̶ ̶T̶e̶s̶t̶e̶d̶ ̶w̶i̶t̶h̶ ̶F̶e̶b̶r̶u̶a̶r̶y̶ ̶B̶E̶T̶A̶ ̶a̶n̶d̶ ̶t̶h̶e̶ ̶s̶l̶u̶g̶g̶i̶s̶h̶ ̶K̶e̶y̶b̶o̶a̶r̶d̶ ̶b̶u̶g̶ ̶i̶s̶ ̶n̶o̶ ̶l̶o̶n̶g̶e̶r̶ ̶p̶r̶e̶s̶e̶n̶t̶.̶
vtpoet
Post by vtpoet »
Update: Weird. After good behavior, the bug has reappeared. Sometimes Textmaker will register all the keystrokes and sometimes it will choke up. It begins with dropping the space bar and gets progressively worse. The old Textmaker HD doesn't have this issue.
lgsl
Post by lgsl »
I have also noticed this. And I think this bug is also related to https://forum.softmaker.com/viewtopic.php?f=397&t=20757
vtpoet
Post by vtpoet »
I reinstalled yesterday. Am I right in thinking SM has issued a new BETA for March? Anyway, I've been testing it on my BOOX and, so far, the previously described bug hasn't reappeared.
Return to “BETA: TextMaker for Android”
